Home Forum Ask A Member Johnson JW-19 Prop shaft seal standard drive Re: Johnson JW-19 Prop shaft seal standard drive
#85169
outbdnut2
    Do you still have the old seal? If so, look for a seal manufacturer’s part number stamped into it, which back then is likely a "CR" followed by 3 or 4 digits. The CR company is Chicago Rawhide, which is now "SKF" SKF’s website has cross-reference tables from the old CR numbers to new SKF numbers, even if it was a special number they set up for Johnson; or you can call them on the phone and customer service will cross ref it for you and tell you where in your area there is a seal/bearing shop where you can buy one. The Johnson part number you have may or may not be a number SKF can cross-reference.
    This site may be what you need if you have the old number stamped into the part:
    http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm
    or put your shaft and bore dimensions in at the site below:
    http://www2.chicago-rawhide.com/popup_parts_lookup_457010.htm
