Info on early 50"s Evinrude Fastwin
grunt
Postby grunt » Tue Apr 10, 2018 12:07 am
Just picked up a 1950 Evinrude Fastwin 14hp I think
There is no ID tag on it anywhere
Cleaned it up yesterday and plan on a full restoration
Just wondering if anyone might have some information on this motor
Plan on putting it on the 1950 Peterborough Aquaflyer that I have been restoring in my spare time for the past 3 years
Thanx
Evinrude Fastwin 14 002.jpg (1.22 MiB) Viewed 327 times
Evinrude Fastwin 14 007.jpg (1.08 MiB) Viewed 327 times
Peterborough boat pictures January 2018 002.jpg (918 KiB) Viewed 327 times
Re: Info on early 50"s Evinrude Fastwin
Postby Garry in Tampa » Tue Apr 10, 2018 1:22 am
Cylinder block, pistons & rings interchangeable with the 1949 12 horse Elto. I seem to have lost some of the pages of the parts book . . . :(
Postby Garry in Tampa » Tue Apr 10, 2018 2:05 am
P.S. That is a model 4438 Fastwin - I had trouble with the rubber motor mounts twisting out of place and put a very short sheet metal screw in each to help hold them in place. It uses a Tiltson MD carburetor. The low speed adjustment adjusts the air. The idle tube supplies a set amount of fuel. It is also easy to clog up with stale oil. The gearcase was also used on the '49 and '50 QD Johnson. . . 8-)
grunt
Postby grunt » Tue Apr 10, 2018 6:59 am
Thanx very much Garry
Much appreciated
RT
Postby crosbyman » Tue Apr 10, 2018 7:57 am
you may want to consult boat info bible....where you usually find the cousin Johnson engines but in 1950 no 14hp are listed only 2.5, 5, 10, 16, 20 hp are listed ??
http://162.144.28.33/
Postby FrankR » Tue Apr 10, 2018 8:30 am
Lower unit is similar to the Johnson QD (10hp) models.
grunt
Postby grunt » Fri Apr 13, 2018 12:31 am
I have been doing some more reading and the 1950 Evinrude model 4438 is 14hp
Should look like the picture attached when it is finished
Hopefully it will get the boat up on plane...no trim tabs on the Woodie
Postby Chris_P » Fri Apr 13, 2018 6:42 am
I have had a couple Aquaflyers. I ran 35hp motors on them. I personally don't feel like you will be happy with the performance with the Fastwin on it sorry.
SquierKA39
Postby SquierKA39 » Fri Apr 13, 2018 11:44 am
That’s the same motor I learned to boat on, mine was on a 1930 Thompson 16’. Performance was fine for a big boat and small motor. We had a speedo on it and I seem to remember 15 mph, maybe 18 tops. My boat can be seen in the pictures page here.
I still have both but have not run the motor in many years.
Jeff Register
Postby Jeff Register » Fri Apr 13, 2018 9:46 pm
Do you have the correct Cruise a day tank? I have an extra one P.M. me, Garry!!! wonderful data & How's that tree :mrgreen:
Jeff
Users browsing this forum: outbdnut2 and 10 guests
