'74 6hp carb kit
PugetSoundBoater
'74 6hp carb kit
Postby PugetSoundBoater » Mon May 14, 2018 10:19 pm
I have rebuilt several of these 6hp carbs over the last few years. Why do they include so many packing washers? The slow speed needle take 2,a fiber one inside and a nylon washer up against the packing nut, shown in the factory service manual.
Is it because this kit is used for several other carb models also?
Screen Shot 2018-05-14 at 7.12.40 PM.png (3.48 MiB) Viewed 283 times
With the same shape float bowl??
Re: '74 6hp carb kit
Postby david bartlett » Mon May 14, 2018 10:28 pm
Jim,
Yes, it fits many models and years.
PS, I got a kick out of the screen shot of your desk top. Looks like mine.
Postby Mumbles » Tue May 15, 2018 3:26 am
They take more than one packing washer on the needle.
Postby crosbyman » Tue May 15, 2018 6:50 am
freebies..enjoy usually parts are missing :)
Postby fleetwin » Tue May 15, 2018 12:51 pm
Yeah, I usually use just two of the packing washers behind the plastic washer...Put the extra ones aside, you never know when you might need them...
Postby Fisherman6 » Tue May 15, 2018 7:13 pm
Jim,
Use two fiber packing washers under a nylon washer on the carb needle. The kits come with enough packing washers for the RDs and Big Twins which use 3 packing washers per needle.
PugetSoundBoater
Postby PugetSoundBoater » Wed May 16, 2018 11:32 am
I have always used the nylon washer right behind the packing nut.It just shows two washers on the needle. I'm sure 3 total will be just fine. Thanks.
Postby Fisherman6 » Wed May 16, 2018 12:40 pm
Yup, 3 works great. I have several done this way including a few 6hp OMCs.
Users browsing this forum: fastjohn, Mas and 9 guests
