1937 Bendix SM
wbeaton
Re: 1937 Bendix SM
Postby wbeaton » Wed May 16, 2018 7:07 am
PM T2 wrote:I see those soldered connections on the fuel pipes, and makes me wonder if solder penetrated to the interior and is at least partially impeding the flow of fuel.
PM T2
The soldered lines blow out clear with lots of carb cleaner flowing through them. The Bendix service manual (I use that term lightly) only says to ensure the soldered connections and welch plugs are sealed. Which they seem be when light pressure is applied. On a side note, I think this is a “pressure carb” developed for aviation. Once I have it working correctly I should be able to run this motor inverted without any loss of performance :D
That’s a good tip, Mumbles. I did catch that right away, but it’s worth mentioning for anyone else that may be following along.
Users browsing this forum: No registered users and 6 guests
