Evinrude ducktwin 3044b approx value
davesko
Postby davesko » Tue May 15, 2018 7:19 am
Hello all, I’m looking for an approx value of an Evinrude ducktwin 3044b in fair to good cosmetic condition, It does not run and will need gone thru. I’m purchasing it from a friend and want to be fair. I know values vary regionally but trying to be fair. I’m in Hershey pa. Thank you, Dave
Leeinnh
Re: Evinrude ducktwin 3044b approx value
Postby Leeinnh » Tue May 15, 2018 7:39 am
beauty is in the eye-------
lindy46
Postby lindy46 » Tue May 15, 2018 9:03 am
How is compression? If it has good compression, most other things can be addressed. Last year I bought a Lightwin which was cosmetically good, but had a broken recoil spring, so I couldn't check compression. I paid $75. I replaced the spring and compression was good, and the motor turned out to be a good runner, so I got a good deal. If I can't hear the motor running, I consider it a parts motor and rarely pay more than $100.
Postby FrankR » Tue May 15, 2018 9:29 am
Being a Ducktwin increases its value over a common Lightwin. Next question is how far away is the nearest Ducktwin collector?
Postby fleetwin » Tue May 15, 2018 12:50 pm
The other thing to check that affects value is the condition of the fuel tank on the inside....A rusted/gummed up tank is relatively useless, finding another Ducktwin tank in good shape would be difficult. It is only fair to assume that any engine you buy will need ignition, fuel system, and water pump servicing. I would have a closer look at this engine, checking compression and looking for cracked/bent castings, inspect the tip of the skeg also to make sure it is not snapped off. A relatively low hour engine in good basic mechanical condition (good tank, good compression, no overheats, no bent/cracked castings) that is in nice mechanical condition is worth about $100 I'd say.
But, like everyone says, it depends on how much you want one of the rarer Ducktwin models. I have certainly spent more than $100 on engines I really wanted.
davesko
Postby davesko » Tue May 15, 2018 5:22 pm
I have inspected this motor years ago. Good compression but will definitely need the usual items to bring it back to life. It fired on some premix. Tank is very clean. Nothing broken off or missing. I have a few lightwins and Jw’s but my son is a big duck hunter and thought it would make a nice gift. I have a feeling my friend thinks it worth a lot of money but I’m thinking 150.00 max.
Kerry
Postby Kerry » Tue May 15, 2018 8:30 pm
If your buddy thinks its worth $$$$, remind him you are paint and decals from making a Ducktwin out of one of your JW/Lightwins. Not a bad idea, if you aren't worried about originality...
If you have too many, AND not enough, you are a collector!
Users browsing this forum: PM T2, SquierKA39, Tubs and 7 guests
