Evinrude Johnson antique outboard motor tool 675023 starter spring winder 1950's
Postby Buccaneer » Tue May 15, 2018 9:10 am
I never seen a tool to wind the rewind springs.
What is the plan "after" you wind the spring on
the gizmo? Bind it with tie wraps or the likes,
then remove it, to drop in the housing?
https://www.ebay.com/itm/Evinrude-Johns ... SwphNa3hJl
Re: Evinrude Johnson antique outboard motor tool 675023 starter spring winder 1950's
Postby FrankR » Tue May 15, 2018 9:17 am
Grab it with a vise-grip pliers and drop it into the housing.
Never had one, never used one, never wanted one. I simply wind the spring into the housing like coiling up a garden hose. Easy
Postby Buccaneer » Wed May 16, 2018 1:18 pm
Frank, some how I've never had one of those rewind springs
go "easy"! Scary when the blow out at you like a ball of spaghetti. :o
Postby Mumbles » Wed May 16, 2018 3:22 pm
I have a small commercial winder here for chain saws and the like but it's too small for our classic motors. I also have a crop from a cylinder sleeve which is the correct size and the plan is to reverse engineer the commercial one some day so I can make one for the OMC's. To be honest, the 'to do' list is getting longer and my spare time is getting shorter.
Starter Spring Winder.jpg (17.79 KiB) Viewed 89 times
Postby FrankR » Wed May 16, 2018 3:40 pm
Buccaneer wrote:Frank, some how I've never had one of those rewind springs
Then perhaps you should buy the one on e-bay. They don't show up very often. ;) ;) ;) ;) ;)
Postby Mumbles » Wed May 16, 2018 3:52 pm
Buccaneer wrote: Scary when the blow out at you like a ball of spaghetti. :o
Like this?
Postby Buccaneer » Wed May 16, 2018 4:04 pm
I saved the photos from EBay as I thought that would
make a fun little project on the lathe, etc.
My project list is also getting too long. Went from
snow on the ground two weeks ago to 88 degrees
today....... lawn is going nuts. :(
opposedtwin
Postby opposedtwin » Wed May 16, 2018 4:54 pm
I try to employ the help of one of my sons when i change a spring. Another set of hands helps a ton! I have found them frustrating too.
Users browsing this forum: Buccaneer and 5 guests
