1930 Elto Speedster Model 310, 14 hp
PM T2
Re: 1930 Elto Speedster Model 310, 14 hp
Postby PM T2 » Thu May 17, 2018 7:53 pm
pgs 2 and 3 for reference
Parts list pg 2-3.jpg (1.18 MiB) Viewed 157 times
PM T2
Postby PM T2 » Thu May 17, 2018 7:54 pm
there, that's all I got time for right now, hope it helps.
Best,
PM T2
Parts list pg 4-5.jpg (1.45 MiB) Viewed 157 times
bobw
Postby bobw » Thu May 17, 2018 8:02 pm
Looks like a real cut-to-shape and beat-to-fit job but somebody made it work with what they had available to them back in the day. Still a cool motor and if you can find the right parts, another piece of history will be restored.
1972 Evinrude 25202
Postby Buccaneer » Thu May 17, 2018 8:27 pm
Dave Bernard wrote:Hope you marked the fly wheel or you wont have it timed correctly.
Dave, I did not mark it, but I hope I don't have to put that cobbled up mess back
together. With all them holes drilled in the flywheel, there's hardly
any "meat" left to hold it together!
Postby Buccaneer » Thu May 17, 2018 8:29 pm
PM T2 wrote:there, that's all I got time for right now, hope it helps.
Best,
PM T2
Much appreciated PM T2. I'll download, blow them up, and start reading!
Postby Buccaneer » Thu May 17, 2018 9:02 pm
Thanks again PM T2, you've answered some of my questions already!
Will look forward to data next week.
Buc
SquierKA39
Postby SquierKA39 » Thu May 17, 2018 10:05 pm
The tank looks correct, the decal is definitely a later addition from a different size tank. Evinrude lettering would not have run around the corner up front, they were to well designed for that mistake. The rest is for the real experts here. Cool motor, good luck with it.
Postby Buccaneer » Fri May 18, 2018 8:29 am
Squire, from what little digging I did, the real early Speeditwin gas
tanks had the fill cap on the port side, and had a gold colored
decal.
I found one photo of a 1946 Speeditwin tank, and another
from the same era, but not dated, other than being a model 6039.
I didn't find any decals where the "E" on Evinrude wrapped around
the corner as far as mine. I don't know enough to be sure it's
even a Speeditwin decal.
First three photos my tank.
Thanks!
P.S.- anyone have photos of the Elto Speedster's flywheel,
timer, coil, what the top of the power head looks like
with the flywheel removed, etc?
Speeditwin tank2 6039.jpg (116.94 KiB) Viewed 137 times
Speeditwin tank 6039.jpg (103.04 KiB) Viewed 137 times
Speeditwin tank 1946.jpg (110.18 KiB) Viewed 137 times
Speeditwin tank 1931-33.jpg (70.39 KiB) Viewed 137 times
Postby Garry in Tampa » Fri May 18, 2018 3:20 pm
The oldest a 6039 Speeditwin could be is 1939. It was the first Speeditwin with a one piece cast muffler. The Speeditwins of 1936, '37' & '38 were Eltos. The Speeditwin tank held two and a half gallons, the Speedifour/Big Four held four. So although the tank decal would fit a Speedifour, it is still incorrect. All the decals I have seen have the name of the motor on the side . . . :roll:
SquierKA39
Postby SquierKA39 » Fri May 18, 2018 10:07 pm
Not the best photos, but that’s mine.
Users browsing this forum: Fishbrick, outboardnut and 20 guests
