1930 Elto Speedster ignition mess
Richard A. White
Re: 1930 Elto Speedster ignition mess
Postby Richard A. White » Sun May 20, 2018 8:55 am
That I do not know, I will defer to the real experts
Richard A. White
MOB Chapter President
PM T2
Postby PM T2 » Sun May 20, 2018 9:24 am
Buccaneer wrote:
Richard A. White wrote:Same guide.....
What I'm really wondering is......
What's the physical differences, say between
a regular Elto Speedster and a Senior Speedster, etc.
Thanks.
And what was the first scan I posted on this subject????
PM T2
Postby Buccaneer » Sun May 20, 2018 11:25 am
Thanks.
PM T2
Sorry, my multi-tasking and memory isn't what it used to be.
Lack of sleep isn't helping. Woke up at 4 am yesterday,
couldn't fall back asleep, so ended up watching
the Royal Shindig. Lots of Pompiousass and Circumstance for sure!
Never seen the Queen Mum crack one smile.
For my penance, for watching the Royal Wedding, and for
forgetting to "blow up" and read the Speedster article......
Here's what I gleaned from it......
Standard Speedster -
Model # -
B x S - 2-1/2" x 2"
8 HP
Special Speedster
Model #-
Larger B x S
HP - 12 ?
Senior Speedster
Model # 310
Extra heavy duty construction
Standard under water silencer
HP - 14
Hi-Speed Option Speedster
"lighter construction"
jimross
Postby jimross » Mon Jun 11, 2018 2:40 pm
Sorry may computer has been down. Elto Speedster could not be converted but A 905 Special Speedster could as I picked up a Sr. that had been converted that way. The later mag. he has on it needs the skirt removed as it is prewar anyway. Get a Timer handle for "U" speeditwin and mount underneath. the holes should still be there and put switch on left side of handle support and you are are more or less correct for 1932-'33. Put a OMC rope plate on it and you are done, it's a '34. Jim
Postby Buccaneer » Mon Jun 11, 2018 2:48 pm
Jim, I ended up getting a magneto and flywheel from a Speeditwin,
and it looks like it will work fine. Right now I'm trying to "re-fit"
the homemade rod bearings that were in it. Thanks.
Users browsing this forum: No registered users and 4 guests
