FDE 11 Piston me Off
effenaco
Postby effenaco » Tue May 22, 2018 4:30 pm
My FDE 11 needs a new piston so I decided to replace the set. Original part number was 376992. It has been superseded by 385338. I ordered a set of these and when I got them they are 2 ring pistons, not three ring pistons which are currently in the motor. Does anyone know if this is a correct replacement and will there be any issues if it is OK to convert? OK experts, weigh in and let me know. Thanks
retiredoz
Re: FDE 11 Piston me Off
Postby retiredoz » Tue May 22, 2018 5:11 pm
Unless the picture is wrong ?
http://www.marineengine.com/newparts/pa ... OMC0385338
In any event, that's what my '75 Johnson parts book calls for for your FD-11.
Postby FrankR » Tue May 22, 2018 6:00 pm
They went to two-ring pistons a long time ago. No problem. Actually, pressure back rings came later on.
Deleted duplicate post
effenaco
Postby effenaco » Wed May 23, 2018 8:00 am
I bought the replacements from Marinengine.com based on that picture, but what arrived were two ring pistons. Then I bought another on ebay and same thing, two rings.
retiredoz
Postby retiredoz » Wed May 23, 2018 2:23 pm
My '69 parts book lists this piston for your FD-11 (383476)
https://www.ebay.com/itm/CLEAN-1969-197 ... SwIGJaN-pY
effenaco
Postby effenaco » Tue May 29, 2018 6:43 am
Yes looked at that one as well. Still two ring even though pictures everywhere show it as a three ring. Again my question is, will there be any problems or other modifications needed to swap the three ring pistons for two ring?
Garry in Tampa
Postby Garry in Tampa » Tue May 29, 2018 7:14 pm
No problems at all. As long as the pistons are properly fitted, two ring pistons are thought to be fractional more efficient (Less drag) than three ring pistons. They are favored in racing motors. Also, adding rings does little to help a poorly fitted piston. . . 8-)
effenaco
Postby effenaco » Thu May 31, 2018 7:48 am
Garry,
Thanks. I just wanted confirmation from an expert. Hope all is well.
Barry
Users browsing this forum: No registered users and 8 guests
