1952 Johnson 25HP (RD-13) crank seal?
jpatti75
Re: 1952 Johnson 25HP (RD-13) crank seal?
Postby jpatti75 » Tue Jun 12, 2018 8:27 pm
10-4!
Thanks,
Jason
Chesapeake Chapter
jpatti75
Postby jpatti75 » Tue Jun 12, 2018 11:00 pm
Alright, I was starting to get everything back together tonight, and my brain failed me on the carburetor linkage. How do I properly install these two pieces. The reason I ask, is that the piece on the left is not on my RD-12/13 diagrams, and I don’t see what purpose it serves (I’m not a smart man). I also noticed that I am missing the large linkage spring that connects to the piece on the right. :?
Chesapeake Chapter
david bartlett
Postby david bartlett » Tue Jun 12, 2018 11:33 pm
Jason,
I found a picture in the Johnson Service manual that may help.
RD CARB PIC.pdf
(353.48 KiB) Downloaded 37 times
Member Pine Tree Boating Club chapter of AOMCI
"I don't fully understand everything I know."
"There is nothing — absolutely nothing — half so much worth doing as simply messing about in boats." (Kenneth Grahame)
jpatti75
Postby jpatti75 » Tue Jun 12, 2018 11:48 pm
Thanks, David. I think the diagram is showing that the piece on the left goes on the linkage shaft first. The linkage rod connected to the carburetor gets connected to the top left hole on the piece on the right. If that is right, I still don’t see what role the piece on the left serves? It doesn’t appear to connect to anything?
Chesapeake Chapter
david bartlett
Postby david bartlett » Tue Jun 12, 2018 11:54 pm
I have no idea about the piece on the left. Gotta love changes from year to year.
Postby FrankR » Wed Jun 13, 2018 8:08 am
Recoil starter lockout???
jpatti75
Postby jpatti75 » Wed Jun 13, 2018 1:45 pm
I've been trying to find pictures of powerheads from the time period on the ol' interwebs. This piece certainly was gone by the time OMC switched to the cam rollers on the linkage in 1955. I've seen a couple powerhead pictures that don't show that piece, just like the diagrams I have for the RD-14/15. I am going to install it in the only way it looks possible to. It doesn't look like it at all comes into play on the carburetor function, so maybe it is some kind of recoil starter lock out like you suggest, Frank.
Does anyone have the part number for the spring that connects the linkage with a small tab on the manifold cover on the RD-13? 303296?
Thanks,
Jason
Chesapeake Chapter
Postby FrankR » Wed Jun 13, 2018 3:19 pm
Closest thing I have is RD-14, shows a spring #303296
jpatti75
Postby jpatti75 » Wed Jun 13, 2018 5:43 pm
Thanks, Frank!
Chesapeake Chapter
jpatti75
Postby jpatti75 » Sun Jun 24, 2018 7:01 pm
Just wanted to say a word of thanks to David Bartlett, Frank, and Ed Elliott for the help and parts for my RD-13. I went into this job thinking it needed the crankshaft seal and a coil, but of course it also needed new condensers, points (it had misaligned Sierra points), ignition cam, one spark plug boot, and carburetor linkage spring. Nothing major, but not the runner it was advertised to be (are they ever!). I ran it on my flushette today, and after a few pulls it fired up and ran very well. I got the carburetor pretty close and hope to get the boat wet next weekend to do the fine tuning.
Thanks for the help, gents!
JP
Chesapeake Chapter
Users browsing this forum: No registered users and 6 guests
cron
