1946 Evinrude Sportsman Model 4412 Repair Manual
Monkeypaws
Postby Monkeypaws » Sat Jun 09, 2018 1:59 am
Hello All,
I was given a neat little motor and I need a repair manual for it. It is a 1946 Evinrude Sportsman 2hp Model 4412. I have been looking high and low but no results. The motor seems to be in good shape but it does need work. If anyone knows where I can get a copy I would greatly appreciate it. Just let me know the cost. Thanks
Re: 1946 Evinrude Sportsman Model 4412 Repair Manual
Postby crosbyman » Sat Jun 09, 2018 6:21 am
http://162.144.28.33/lib/johnson/manual ... hnson.html
2hp... or 2.5 ?? look up hd25 cousin in Johnson motors
Postby Garry in Tampa » Sat Jun 09, 2018 10:37 pm
Evinrude and johnson were different in those days. some rewind starter parts are the same. The HD Johnson is a twin, the Evinrude is a single. The Sportsman carburetor is more like the one on the Row Boat Motor. I think it is easier to work on . . . 8-)
The 171449 capacitor (condenser) should read between 0.09 and 0.125 µƒd (MFD), The coil primary should be 2 to 4 ohms, secondary 4 to 7 K ohms. The breaker points are set at net high point of the cam to 0.020" and the Champion J6C ((NGK B6S) in gapped to 0.030".
The carburetor will probably need needle valve packing. Only tighten the packing nut enough the keep the needle from moving. The fuel filter in the bottom of the float bowl is 100X100 copper screen. with a film of oil it will stop water.
Users browsing this forum: dmbono, itchy, Lyks2Tinkr, NJ-boatbuilder57 and 7 guests
