never seen this before...
Postby fleetwin » Sun Jun 10, 2018 10:16 pm
https://www.ebay.com/itm/1994-Evinrude- ... Sw7kVbHU3v
Auction says this mag plate is from a 94 48spl...But, sure don't recognize those ignition parts...Looks like an old driver coil along with some sort of crazy sensor set up....
After market replacement pieces??
Dan in TN
Re: never seen this before...
Postby Dan in TN » Sun Jun 10, 2018 10:56 pm
I think if you look at the parts break down you will see this is a CDI charge coil replacement. They just sell the coil without laminates.
I looked thinking maybe it was replacement for UFI, but I guess it was long gone by then. I don't remember the plate with the sensor under it? Anyway if the charge coil is CDI then I guess some of the other stuff could be too or I have just forgot how it looked.
Dan in TN
Postby fleetwin » Tue Jun 12, 2018 9:10 am
Yeah, was wondering if this is one of those UFI-CDII conversion kits...The charge coil with its missing potting/laminates fooled me as well...I guess that metal mounting bracket is necessary because there were no mounting bosses for the sensor on the UFI mag plates...
Dan in TN
Postby Dan in TN » Tue Jun 12, 2018 11:16 am
CDI doesn't pot their windings/laminates except for ignition coils. Says they run cooler that way. I always wondered about salt water corrosion? Anyway when you see a stator or driver coil that is open you usually know it's CDI. I'm still not sure about the plate that is mounting the sensor? I thought UFI was gone by then.
Dan in TN
Postby fleetwin » Tue Jun 12, 2018 1:56 pm
Maybe it is from a 93 model, they still used UFI in 93...
Dan in TN
Postby Dan in TN » Tue Jun 12, 2018 2:12 pm
There it is fleetwin. 1993 40hp. CDI kit #113-4489. Even says this side up with sensor coil underneath. That answers that. Check it out.
http://www.marineengine.com/parts/image ... 3-4489.jpg
Dan in TN
Postby fleetwin » Tue Jun 12, 2018 5:53 pm
OK, well now I know what these conversion kits look like...D
Postby Garry in Tampa » Tue Jun 12, 2018 8:44 pm
Fastenating - much too new an antique for me . . . :roll:
93 Stator Kit.png (541.07 KiB) Viewed 668 times
94 Stator assy.png (1.47 MiB) Viewed 668 times
Users browsing this forum: Google [Bot], opposedtwin and 8 guests
