12hp scott mac. coils
csw
Postby csw » Fri Jun 15, 2018 12:51 am
I'm almost done with my 12hp scott mac. A3FB 2153, and I'm having a problem finding a coil. I checked with discount marine, and are out of stock. I remember reading about a Tecumseh coil that might work. I have also been told to cut down the coil heals and use omc coils. I could use some advice. Thanks. csw
Re: 12hp scott mac. coils
Postby FrankR » Fri Jun 15, 2018 10:41 am
Is that a Repco mag? I haven't tried to buy any coils, but I would think they ought to be available. More info would help.
Postby amuller » Fri Jun 15, 2018 11:51 am
I don't know, but Tecumseh ignitions often seem to be Repco (Phelon) clones. It's possible that Tec lawn mower coils (point type!) might work.
http://tewarehouse.com/460-063
https://www.walmart.com/ip/Stens-460-06 ... /192857940
https://www.amazon.com/Replacement-Igni ... text&psc=1
Postby Mumbles » Fri Jun 15, 2018 11:55 am
OMC/BRP coils were used in my '60 Scott-McCulloch 12 horse but I don't recall having to modify the laminations. If anything, epoxy was used to help hold them on.
csw
Postby csw » Fri Jun 15, 2018 10:31 pm
I checked, and my mag was built by Phelon. CSW
Postby FrankR » Sat Jun 16, 2018 6:31 am
If you will post the Phelon (Repco) model number of the magneto, we can look up the Phelon part number for the coils. The Phelon model number will be stamped on the magneto plate
jnjvan
Postby jnjvan » Sat Jun 16, 2018 11:57 am
I have used the following coil successfully (substitute for Tecumseh 30560A).
http://tewarehouse.com/7-01612
John Van
Postby amuller » Sat Jun 16, 2018 12:38 pm
jnjvan wrote:I have used the following coil successfully (substitute for Tecumseh 30560A).
John Van
The price is good, also.
csw
Postby csw » Mon Jun 18, 2018 11:05 am
I finally got the number on my phelon mag F-189. Thanks. csw
Postby FrankR » Mon Jun 18, 2018 1:04 pm
I'm still lost. But the list may not go new enough anyway.
Users browsing this forum: destroyer85golf, Google [Bot] and 13 guests
