55 RDE-17, 25 hp, Power Head O-rings, etc
NJ-boatbuilder57
Re: 55 RDE-17, 25 hp, Power Head O-rings, etc
Postby NJ-boatbuilder57 » Tue Jul 10, 2018 6:35 pm
What pressure to you all test with? 2 or 3 PISG? More? Less?
Postby fleetwin » Tue Jul 10, 2018 7:15 pm
Buccaneer wrote:Sounds like good logic Fleetwin.
Making a pressure tester is on my "list". I would think it would
be handy also when you know you have a leak, but not sure
where. Haven't tried draining the LU yet. Clean and sandblaster
some parts this morning. All afternoon has been mowing and
tending gardens. :-(
Thanks.
fleetwin wrote:Just don't be fooled by faulty gage set ups...I am not criticizing home made stuff, I have had plenty of Stevens testers show false leakage in the gearcase, when the true problem was a gage issue, hose, valve etc...
I guess what I am saying is that if the gear lube comes out without showing signs of water, I would probably just refill and run it...Needless to say, I would change gear lube frequently to ensure all is well. Running it "as is" will give you a chance to make sure the clutch dog is OK as well...
Needless to say, if the lube shows signs of water, then you should pressure test to find the actual problem before resealing...
Oftentimes test equipment that was designed to help us, ends up confusing us with false readings/wrong conclusions....
Yes, having a decent/reliable pressure tester is a must, just like the OMC flywheel puller kit....I like the designs shown here, very simple, I like the idea of using a bicycle pump to make sure you don't over pressurize the gearcase....
I guess sometimes it is best to "not look for problems where there aren't any...."
Postby Buccaneer » Thu Jul 12, 2018 4:17 pm
I made me a lower unit pressure tester this morning.
Hopefully I didn't infringed upon one of your patents. :o
Hooked it up to the subject motor and gave it a few pumps
and heard air leaking right away. Some soap suds confirmed
it was the shift rod seal.
The LU oil I drained out was fresh as a new picked daisy,
but the PO probably changed it before it was laid up.
No clue of how many years since it was run.
LU. Pressure Tester2.JPG (476.54 KiB) Viewed 47 times
L.U. Pressure tester1.JPG (470.34 KiB) Viewed 47 times
Postby Chris_P » Thu Jul 12, 2018 4:57 pm
Bucc great tool ill take 2! :)
Postby Buccaneer » Thu Jul 12, 2018 6:14 pm
I think I'll let "manufacturing" tools for sale up to Richard!
I had all the stuff on hand, but it took me about 2-1/2 hours
to get er done. My mere lathe skills are "on the job training",
and I do a lot of "winging it".
Postby Richard A. White » Thu Jul 12, 2018 6:25 pm
I hear ya....LOL
Contemplating this one....
Postby Fisherman6 » Thu Jul 12, 2018 7:14 pm
Nice job Buc! It looks like it may have been inspired by mine. Glad to be an inspiration if in fact it was. No patent infringements here. ;)
NJ-boatbuilder57
Postby NJ-boatbuilder57 » Thu Jul 12, 2018 7:53 pm
What PSI do you test to?
Postby Buccaneer » Thu Jul 12, 2018 8:25 pm
Ben, I must admit, I did look at your tester again before I headed out
to the garage this morning. :D
Fisherman6 wrote:Nice job Buc! It looks like it may have been inspired by mine. Glad to be an inspiration if in fact it was. No patent infringements here. ;)
Postby Buccaneer » Thu Jul 12, 2018 8:31 pm
I'm not sure myself. What's the general rule fellows?
My shift shaft seal was leaking so bad it didn't hold
any pressure, but the gauge would bounce up to 3 to 5 psi
as I ran the tire pump.
NJ-boatbuilder57 wrote:What PSI do you test to?
Users browsing this forum: bobw and 5 guests
