prop shop
green thumbs
prop shop
Postby green thumbs » Mon Jul 09, 2018 6:19 pm
Bronze prop bit off more than it could chew...is it worth while to have repaired?
Would appreciate comments from those who know.
prop is a Michigan Wheel K32
A KF7 KG7 Mercury specific prop that has internal teeth to mesh with fiber and stainless steel disc set up.
Thanks
Louis
wbeaton
Re: prop shop
Postby wbeaton » Mon Jul 09, 2018 6:47 pm
I guess it depends on the damage. Prop repair isn’t that expensive. Most of the time it’s worth the effort.
Re: prop shop
Postby Dave Bernard » Mon Jul 09, 2018 7:30 pm
they are hard to get. with that said they can be repaired. don't throw it away. give or sell it IF you don't repair it. Dave McKinney does good work. 1 706 319 1960 is his ########
Re: prop shop
Postby FrankR » Mon Jul 09, 2018 9:13 pm
Where I worked, the prop shop sent their guy every week to pick-up & deliver. That brass prop would come back repaired, polished, and looking like brand new. Heck yes, worth it. Likewise, aluminum props, but once the paint is knocked off you can see the repair. Actually, the repaired area is stronger than the original aluminum.
