1963 Sportwin - Exhaust Leaking Out of Shift Rod Cover Plate
h20lew
Postby h20lew » Wed Jul 11, 2018 12:08 am
I bought a 1963 Evinrude 10HP Sportwin parts motor for not much money. Thought I'd fire it up before deciding what to do with it and it ran OK, not great but OK, but I noticed that it was leaking milky exhaust out of the shift rod access cover plate which is a condition I've never seen before. Just looking for thoughts on what causes this. Thanks.
Screen Shot 2018-07-10 at 11.00.13 PM.png (254.96 KiB) Viewed 203 times
bobw
Re: 1963 Sportwin - Exhaust Leaking Out of Shift Rod Cover Plate
Postby bobw » Wed Jul 11, 2018 12:11 am
Exhaust gas and unburned fuel/oil mix causes the foamy/milky appearance. You just need a new gasket under the shift plate cover.
1972 Evinrude 25202
Postby david bartlett » Wed Jul 11, 2018 12:14 am
What Bob said!!!
chris
Postby chris » Wed Jul 11, 2018 12:39 pm
It seems that the slime would go out the path of least resistance. Is there a chance that the lower normal path is blocked? Just doesn't seem like it would blow through that cover like that.
1955 10hp, 25hp, 1957 18hp Johnsons. 1958 35hp, 1972 50hp Evinrudes. Among others...
Postby Fisherman6 » Wed Jul 11, 2018 1:33 pm
At lower speeds and while the motor is not up to temperature, the entire inside of the housing is covered with that gray slime. If the gasket has a leak or a chunk missing, the exhaust pulses will push it right out and around the cover as well as out the exhaust.
cajuncook1
Postby cajuncook1 » Wed Jul 11, 2018 2:24 pm
Agreed, that gasket is toren or missing. Easy to make one with gasket material.
Cheers,
Cajun
Postby Mumbles » Wed Jul 11, 2018 3:54 pm
Has that motor been sneezing? Someone, please, give it a Kleenex!
Users browsing this forum: rjoynt and 14 guests
