1960 15HP Gale Buccaneer Sea King
crosbyman
Re: 1960 15HP Gale Buccaneer Sea King
Postby crosbyman » Tue Aug 07, 2018 5:29 pm
should be a o ring under that brass sleeve
changing the oring is not so bad…………….. lots of Utubes on it
me….. I used the tap and rod method with a block of wood worked great on my oldies
https://www.bing.com/videos/search?q=ut ... &FORM=VIRE
if oil is not recent and… remains waterless maybe you should NOT FIX IT for now
clean out that L'/U cavity that drain hole should drain. I cleaned out a Merc 4hp with sand and crud an inch thick down that cavity
markpatty72
Postby markpatty72 » Tue Aug 07, 2018 7:01 pm
Thank you. That’s very encouraging.
markpatty72
Postby markpatty72 » Wed Aug 08, 2018 12:30 pm
The 15 hp Sea King runs well and water pump works fine. My Ignorance was the problem. Disassembled everything. Water pump was is in good condition. Reassembled everything. Water muffs do not work on this engine as previously stated by FrankR. Covered the lower foot as high as the water pump in a large container of water. Started the engine and water began to come out the upper exhaust port almost immediately. Its amazing an engine almost as old as I am works so well. Cranks first pull.
Thank all of you who have contributed to healthy outdoor activities and away from Internet games. I can now take my son-in-laws fishing and my wife, kids and grandkids for a little trip on the lake.
Thank you so much!
Mark
crosbyman
Postby crosbyman » Wed Aug 08, 2018 12:50 pm
and grand kids will one day use grand pa's motor if you oil it properly :lol:
markpatty72
Postby markpatty72 » Wed Aug 08, 2018 2:27 pm
I will keep it oiled:-)
Speaking of oil, I have used 24 to 1 fuel / synthetic oil mix. Apparently a lot of oil is not being burned because oil was seeping out the lower foot seam and weep hole. I was told by the man I bought it from he ran 40 to 1 synthetic oil mix. He said he did not run the engine very much. He was in old retired Navy submariner. I know there is much controversy over fuel oil mixes.
Does anybody have any real data that might help as I would like to use as little oil as possible?
crosbyman
Postby crosbyman » Wed Aug 08, 2018 4:38 pm
oil is cheap…. if you are worried about the pollution… you can use bio degradable oils like BRP xd100 $$$ about $50 gal and it is good for the innards of the engine (almost...no smell, no carbon build up)
Users browsing this forum: crosbyman and 8 guests
