Struggling with drum and pulley steering
Stanley
Re: Struggling with drum and pulley steering
Postby Stanley » Fri Jul 27, 2018 4:05 pm
Both cables come of the top of the steering wheel drum?Make sure the motor swivels easily when not hooked to cables.
Severi
Postby Severi » Fri Jul 27, 2018 4:54 pm
Okay that could be the problem in the diagram it looks like the wire comes off the bottom of the inside drum. So both should come off the top of the drum?
Postby Dave Bernard » Fri Jul 27, 2018 5:02 pm
DEPENDS ON WHERE THE STEERING IS HOOKE UP. IF IN THE FRONT THAT IS TRUE UNLESS YOU RUN DOWN ONE SIDE ONLY. COMES OFF THE BOTTOM IF THE HOOKUP IS ON THE REAR OF THE MOTOR LIKE MOST RACE MOTORS.
Severi
Postby Severi » Fri Jul 27, 2018 9:59 pm
The wires run down both sides of the boat, the drum is on the steering wheel under the dash just to clarify.
bobw
Postby bobw » Fri Jul 27, 2018 10:30 pm
With one cable on each side of the boat, both cables need to wind off the top of the drum.
1972 Evinrude 25202
Postby Garry in Tampa » Sat Jul 28, 2018 2:19 am
You're in for a BIG surprise if you get them backwards . . . :o
NJ-boatbuilder57
Postby NJ-boatbuilder57 » Sat Jul 28, 2018 8:19 pm
I don't mean to hi-jack the thread, but can anyone tell me what size / lay / material the cable should be? I've been using rope (Yeah, I know...), and I want to re-do it properly.
bobw
Postby bobw » Sat Jul 28, 2018 10:11 pm
Typically use vinyl coated wire rope (cable). Diameter size depends on what size pulleys you are using.
1972 Evinrude 25202
NJ-boatbuilder57
Postby NJ-boatbuilder57 » Sat Jul 28, 2018 10:14 pm
'57 Johnson 35HP...the pulleys look like they're about 2" diameter, but the groove isn't very big at all....
bobw
Postby bobw » Sat Jul 28, 2018 10:26 pm
Take one of the pulleys with you to a supply house and do a trial fit. Maybe 3/16" diameter.
1972 Evinrude 25202
Users browsing this forum: Google [Bot], Seagull764 and 8 guests
