1955 Evinrude 15014 transom bracket
Bob D
Postby Bob D » Tue Aug 07, 2018 12:03 pm
Will the transom brackets from a 1960 18HP Evinrude 15302 fit a 1955 15HP
15014 ? Different part numbers, but look very similar?
Thanks,
Bob D
Steve D
Re: 1955 Evinrude 15014 transom bracket
Postby Steve D » Wed Aug 08, 2018 7:48 am
Hey Bob, That should fit just fine. Unless I'm missing something and you're seeing something I'm not, the parts appear to be the same when I compare numbers from the '55 manual and numbers at MarineEngine for the '60.
55E15 parts.jpg (150.1 KiB) Viewed 92 times
55E15 parts2.jpg (136.36 KiB) Viewed 92 times
60E18 parts.jpg (76.12 KiB) Viewed 92 times
Well, it didn't look like a two-horse town, but try finding a decent hair jelly.
Postby Richard A. White » Wed Aug 08, 2018 8:37 am
I ask how they have 4 of one side in stock and none of the other? Interesting...
Steve D
Postby Steve D » Wed Aug 08, 2018 9:01 am
Maybe more of a demand for the port side because of this part of the bracket. Over the years I've seen a few of them broken off right there.
55E15 parts3.jpg (146.14 KiB) Viewed 72 times
Bob D
Postby Bob D » Wed Aug 08, 2018 12:53 pm
Thanks Steve, that's the same method I used to check the part numbers.
I used my parts book for the 55, and MarineEngine for the 1960. I guess I need new glasses. Thanks for helping out an old (65) man.
Here is a diagram showing the crack on my mount. Not in the usual place. How in the heck did the previous owner crack that??? It's unbelievable how banged up some of these old motors are. It's almost as if they send them down a flight of stairs!
Bob D
Magical Snap - 2018.08.08 12.41 - 003.jpg (136.95 KiB) Viewed 44 times
bobw
Postby bobw » Wed Aug 08, 2018 1:23 pm
Bob D,
Unless you want to use the parts from a 1960 motor, here's another source for a used complete stern bracket assembly from a 1957 Johnson 18hp that will also fit your 1955 15hp.
http://thebrazilianconnection.com/57johnson18parts.html
I've bought lots of used parts from this site and never got a bad piece - always quality used parts.
1972 Evinrude 25202
Bob D
Postby Bob D » Wed Aug 08, 2018 1:36 pm
Thanks Bob, I had access to buying a 60 bracket.
I have also used Brazilian Connection, and can vouch for them as well. Good pricing, and quick delivery.
Bob D
Users browsing this forum: FrankR, Google [Bot], PugetSoundBoater and 15 guests
