OMC tach 122923
OMC tach 122923
Postby amuller » Thu Aug 09, 2018 2:02 pm
Picked this up at Tomahawk. Can't remember if I paid $1 or $2 for it.
In any case there are four leads: blue, black, gray, and purple, and a pulse/rev dial with settings of H, 2,3, 4, and 6.
Can anyone point me to a data sheet for this, or tell me which wire goes where?
And will this tach work with an early 70s CI ignition? I vaguely recall that there was a special tach for those. I also think there is a gray wire from magic box, not otherwise used, that might be for the tach.
Thanks for any help.
Re: OMC tach 122923
Postby FrankR » Thu Aug 09, 2018 4:15 pm
Well the wires are simple enough. Blue to running lights (dial illumination) Black ground, gray pulse signal, purple switched 12V. I think it might be an universal tach, but that's guessing.
BillW
Re: OMC tach 122923
Postby BillW » Fri Aug 10, 2018 5:43 am
Early seventies should have a rectifier in the charging system, if I remember right. You would hook up the wires as Frank said, hooking the gray wire to one of the yellow wires at the rectifier, preferably the one with a gray tracer. I am going on memory but I believe you'd put the switch on 6. Then the tach should work, providing that the charging system is working to start with.
Users browsing this forum: crosbyman and 4 guests
