Can a Hard Pull be remedied for an old man?
paulfromYork
Postby paulfromYork » Sun Sep 09, 2018 12:49 pm
I have a 12 hp Gale, and the last time I was out, I had some trouble starting it. My little 12 ft. Tinny has a walnut shell paint job on the bottom. Very good for traction. Very bad for old knees. I had road rash on them for several weeks!
Is there any way to modify an old twin cylinder with a compression release? Or how about an electric start? I'd rather it be easier to pull!
(Yes, I could just kneel on an old towel, but a compression release would be more fun!)
Re: Can a Hard Pull be remedied for an old man?
Postby FrankR » Sun Sep 09, 2018 12:58 pm
Model number of your Gale is??? Some can be fitted with electric start, some not.
Postby Dave Bernard » Sun Sep 09, 2018 8:54 pm
I have a real nice 18 HP evenrude electric if needed.
John C
Postby John C » Sun Sep 09, 2018 9:55 pm
This is where you start inviting younger people on your outings. Give them the thrill of starting and running the old motors.
jw in dixie
Postby jw in dixie » Sun Sep 09, 2018 11:26 pm
I have the same problem - tore rotator cuff on my pulling shoulder. Thought of a custom larger rope sheave screwed to the wheel. Have not been out this year. :(
JW in Dixie
paulfromYork
Postby paulfromYork » Mon Sep 10, 2018 1:03 am
Dave B, I have a 12 ft tinny! The 12 is already 2 over. 18 would be 8 over. And the thing might not float for very long.
So, compression release not possible?
Postby FrankR » Mon Sep 10, 2018 7:00 am
Anything is possible if you have enough money to have something custom manufactured. But no, there is no stock off-the-shelf compression relief system for that motor.
Still waiting for the model number.
Postby Garry in Tampa » Mon Sep 10, 2018 12:10 pm
The oval rope sheave is a little easier to pull as it has greater leverage when going against compression. It would require changing the flywheel and starter housing assembly. . . :?:
Postby Garry in Tampa » Mon Sep 10, 2018 12:47 pm
On the other hand, I had a neighbor with a 16' Wolverine powered by a Sportfour with a simplex starter. He installed a steering bar and remote controls. He extended the starter rope through a series of pulleys along the keel to a pulley under the forward deck back down to a pulley on the end of a hinged board and anchored back under the deck. The weight of the board was countered by a door spring. It wasn't pretty, but he cranked the motor by stepping on the board . . . 8-)
EvilTwin
Postby EvilTwin » Mon Sep 10, 2018 2:24 pm
Drill, baby, drill...
https://m.youtube.com/watch?v=6Y4QJBUOaS0
Only would be feasable if you can easily remove the shroud & recoil or on older motors that have the sheave/flywheel nut exposed.
Or if you really don't like your feet:
https://m.youtube.com/watch?v=2OLFu-4PwsA
I am not responsible for any injury or damage. :D
Users browsing this forum: Chinewalker, Google [Bot] and 3 guests
