Home Forum Ask A Member Mid 50’s Johnson 25HP runs like crap. Advice needed
Viewing 10 posts - 1 through 10 (of 39 total)
  • #9928
    huntleybill
      I got this 25HP Johnson and am trying to get it to run better… a LOT better!
      I have attached a couple of videos for your viewing pleasure. Here are some specifics.
      The motor has been sitting for years inside. (So the previous owner tells me.)
      The motor ran fine the last time it was used (famous last words).
      The coils, points, spark plugs, wires are new (plugs are NGK) I cleaned and re-gapped points to .20, plugs to .25
      Carb was spotlessly clean. Hoses were dry rotted so I replaces them.
      Compression is 110 on both cylinders.
      Because it has not been run in years, I put 16:1 fuel mix in it. It still should not smoke like it does.
      I have to run the motor with the high speed at at least 2 1/2 turns or more to keep it running. Or keep the choke 3/4 closed.
      You can forget about an idle!
      Both plug wires have nice blue spark. Even when I pull the plug wire off, I can see a blue park jump to the plug, but it runs like crap.
      I thought it was a carb issue until I played with pulling the plug wires off while running. (see videos)
      Can you help me with why this motor runs so bad?
      Thank you for your help.
      https://youtu.be/W8S3BAh-EQY
      https://youtu.be/CGo7etm01S0
      david-bartlett
        Bill,
        That is smoking a lot. Due to running very rich, and with the choke partially closed. You said carb was clean? Did you take the welch plug out and check the low speed area?
        If it has to run with the choke, there is a fuel delivery issue there somewhere.
        With 110 psi compression, it should run and idle fine.
        Fuel filter plugged up?
        #76002
        huntleybill
          Thanks David
          I did not take the welch plug out.
          Your right, it is running rich but as you can see in the videos, the motor sneezes a lot as I turn the mixture leaner or open the choke. The throttle is wide open at this point so I wouldn’t think the idle was a factor. Is it???
          Fuel filter was clean.
          #76003
          pm-t2
            Canada Member - 2 Years
            Yeah you’ve got some impediments still lurking in the carburetor. Its not cleaned out yet.
            Is that really all smoke? Looks like mix of smoke/steam. Smoke will hang there and eventually you can’t see anymore, that stuff looks like its dissipating. How much cooling water is it putting out? Almost looks like the water tube grommet is pinched or squished and not enough water getting upstairs, and what does get there comes out as steam instead of just warm water.
            Hope it helps.
            Best,
            PM T2
            #76004
            david-bartlett
              Bill,
              Is the Magneto synchronized with the carb?
              You didn’t mention what effect(if any) the low speed adjustment has. I suspect the idle circuit is plugged as it won’t run with the butterfly closed. All that fuel from the high speed circuit is essentially flooding the engine, so unless the low speed needle is fully closed, you need to have another look at the carb.
              JMHO
              #76008
              crosbyman
                smoke if not steam….===> to much gas/oil being burnt
                have all carb passages been ..really cleaned inspected air blown (forward and backward )
                are the float and inlet needle doing there job ?
                have you adjusted the float
                is the float good and not upside down
                have you done a blow test on the float (no air in when upside down)
                is this a fresh gas & oil mixture
                #76010
                Steve D
                  quote Huntleybill:
                  Both plug wires have nice blue spark. Even when I pull the plug wire off, I can see a blue park jump to the plug, but it runs like crap. I thought it was a carb issue until I played with pulling the plug wires off while running. (see videos)
                  I can’t tell for sure from the video, but it didn’t seem to make much difference when you pulled the top plug wire. Aside from whatever carb issues you might have, is the spring clip making good contact with that wire in the boot? Is the wire fully inserted/screwed into the coil making good contact with that pin?
                  #76011
                  donsmarine
                    16:1 might be a little rich, I don"t think anything makes blue smoke other then oil
                    #76013
                      I think you are barking up the wrong tree (carb tree). There is something wrong with that top cylinder. You claim the spark is not the issue, so look for something else. Crankcase sealing? Water getting into cylinder? Scored piston? Busted reed? But first double check the ignition.
                      The smoke is because the top cylinder is not burning its fuel, but is discharging it into the exhaust.
                      #76016
                        Looks like it’s burning kerosene. 😮
