33hp skitwin, intermittent miss
vtfireman85
Re: 33hp skitwin, intermittent miss
Postby vtfireman85 » Tue Sep 18, 2018 9:46 pm
So ignoring the advice of fleetwin I pulled the gearcase apart, I see no issues with the clutch coupler, no metal filings in the oil, it all looks good, I’ll post pictures tomorrow. So on to ignition, I bought new plug wires I’ll install them
Tomorrow or the next day. It’s ok, I’m good with having dismantled the gearcase, I now will know what’s inside as far as wear and any issues, it had been “gone through” by a reputable individual but I like knowing what I am looking at. Stay tuned. As a side note, what is the general consensus on running the engine in gear with earmuffs hooked to the garden hose?
Postby Garry in Tampa » Wed Sep 19, 2018 12:12 am
It is the same as running in neutral except for the danger of the spinning propeller. The best "Earmuff" is the one that replaces the by-pass cover above the anti-ventilation plate on the port side of the motor with one that has a garden hose connector . . . :D
cajuncook1
Postby cajuncook1 » Wed Sep 19, 2018 8:18 am
vtfireman85 wrote:So ignoring the advice of fleetwin I pulled the gearcase apart, I see no issues with the clutch coupler, no metal filings in the oil, it all looks good, I’ll post pictures tomorrow. So on to ignition, I bought new plug wires I’ll install them
Since you have opened the can of worms (gearcase), please post pictures of the clutch dog, forward gear, reverse gear, and pinion gear. Wash them well so so the pictures can show if there is wear that requires replacing. Used the knowledge base that is available to you.
Cajun
Postby Jerry Ahrens » Wed Sep 19, 2018 8:43 am
If the lugs on the clutch dog are rounded off, even a little, that will cause the jumping out of gear problem. The lugs on the gears and the clutch dog must be perfectly squared, with no rounding or rolling over on the edges. A new fwd and reverse gear, along with a new clutch dog, is required to fix this. If you have ran the motor like this very much, the gears and clutch are likely shot.
cajuncook1
Postby cajuncook1 » Wed Sep 19, 2018 10:28 am
Vtfireman85:
You have a bunch of really knowledgeable guys trying to help you out. There are questions that need answering and you need try to follow a systematic approach.
First, post pictures of your forward gear, Reverse gear, clutch dog and pinion gear. Then you will need to reseal your gearcase.
You stated,
its what I am wondering, clutch dog will be easy to diagnose and fix once I am out of the water, the other I wondered if it was also too lean, this engine is quite tight so I know its not leaning out around the crank shaft. id really like a prop wheel so I can try to diagnose this at home. I have also wondered if I am out of adjustment on the shifter, I am going to go look into that now. I would absolutely describe the high end issue as feeling like I ran over something and here in Squam lake, thats always a possibility. when god got done making lakes he put the extra boulders here, so it is especially alarming
I don't know what you are referring to in regards to carburetor. Lean sneezing can happen in Forward gear, neutral and Reverse. A lean sneeze will become more pronounced(more prominent skip or hard jerk feeling) at higher speeds. Your carburetor has a low speed/idle needle number #30 and I high speed needle #58 in the diagram provided.
You never stated if you adjusted carburetor while you were in the water and on the boat. You dial in your high speed needle first then you make adjustment to the low speed/idle needle second.
Before you tear into the ignition, get a set of inline neon spark detectors and look for intermittent spark loss while the engine is running.
Like the others have stated, your motor should not be jumping in and out of gear in neutral.
Make sure these are your beginning carburetor settings:
(Carburetor Adjustments for High speed and low speed/idle needles)
Initial settings are: Bottom high speed = seat gently (turn needle clockwise), then open 1 turn out(counter clockwise). Top slow speed = seat gently(turn needle clockwise), then open 1-1/2 turns out (counter clockwise). Once you have adjusted the idle/slow speed needle and the high speed needles, then snug up/ tighten (packing nuts) part numbers 30 and 58 with 7/16 open in wrench enough to feel resistance when you turn the needles, but not too much where it makes it very difficult to turn the needles by hand.
Setting the high and low needle valves properly:
NOTE: These settings should be done a large test barrel or on the boat in the water/lake!! It best to do these adjustment on the boat in the lake or on commercial size test tank. (You can damage your motor running it wide open in a small test barrel.)
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn in (clockwise), waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out (counter clockwise) the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turn in (clockwise), start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn (counter clockwise). Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
vtfireman85
Postby vtfireman85 » Thu Sep 20, 2018 4:10 pm
Cajuncook, thank you for all the adjustments procedures, I’ll save those for future reference as well. I have reason to feel the carburetor needs further attention however I am awaiting a kit.
Meanwhile here are the pictures from my lower unit gearbox I believe there is a thrust washer missing, and I also believe that I have sufficient clutch dog wear to warrant replacement. Please give me your thoughts.
bobw
Postby bobw » Thu Sep 20, 2018 4:21 pm
That clutch dog is toast.
1972 Evinrude 25202
vtfireman85
Postby vtfireman85 » Thu Sep 20, 2018 4:25 pm
Also I just found the other washer, it was stuck to the gear.
Postby fleetwin » Thu Sep 20, 2018 9:21 pm
Yep, clutch dog is history....Would need more pictures of the gear lugs to make a decision on it...
vtfireman85
Postby vtfireman85 » Fri Sep 21, 2018 7:14 am
That’s all I’ve got, they didn’t look as bad but I did wonder if they were interchangeable, could they be turned around so they engage the opposite side? Same with the clutch dog? I don’t mind buying new parts but if I can just turn it around...
