Champion outboard
sjohnson
Champion outboard
Postby sjohnson » Mon Sep 17, 2018 7:56 pm
I Purchased to 1946 champion 1J blue ribbon outboards I would like to rebuild the carburetor and reseal the lower unit can anyone help me on where to find parts and schematics ?
retiredoz
Re: Champion outboard
Postby retiredoz » Mon Sep 17, 2018 8:03 pm
Discount marine says they have the carb kit (Tillotson ME-1)
cajuncook1
Postby cajuncook1 » Mon Sep 17, 2018 8:13 pm
cajuncook1
Postby cajuncook1 » Mon Sep 17, 2018 8:15 pm
cajuncook1
Postby cajuncook1 » Mon Sep 17, 2018 8:26 pm
Look at the pdf below. It shows the different motors from different makers that use the Tillotson carburetors. Some of those share the same needle and seats as well as gaskets numbers and kit numbers. May make it easier to find what you need.
sjohnson
Postby sjohnson » Tue Sep 18, 2018 10:24 pm
That book is great help. Does anyone sell parts for the Champion outboards?
cajuncook1
Postby cajuncook1 » Wed Sep 19, 2018 11:06 am
As far spare parts for your, you would have find a parts motor. You can place a want Ad here on the AOMCI Webvertise section. There many members that have Champion parts motors. As for as the carburetor, retiredoz made an excellent suggestion for a carburetor kit or you can make the gaskets yourself.
In regards to the ignition, test your ignition to see if the coil, points, and condenser are still good. If you need to replace the spark plug wires, then you should get 7mm copper core wires and not the automotive stuff. You can purchase 7mm copper core wires at local lawn mower shop, Tractor shops, and some automotive shops. You can even get them on Amazon.com.
https://www.amazon.com/Black-Spark-Plug ... +and+boots
If your coil is bad, then you will have to identify the type of coil and report back to the forum for suggested replacements.
Your gearcase uses grease and not gear oil. Good gear case grease are Corn Head grease and Lubriplate 105.
Cheers,
Cajun
Postby FrankR » Wed Sep 19, 2018 1:19 pm
It would appear it is a Bendix Scintilla mag / coil. AKA Mercury.
sjohnson
Postby sjohnson » Thu Sep 20, 2018 8:44 am
What spark plugs work in the 1946 champion 1j?
RCO
Postby RCO » Thu Sep 20, 2018 8:58 am
It originally called for a #9 champion plug which supercedes to a D21.
