Old prop ID
Count
Old prop ID
Postby Count » Sat Sep 22, 2018 9:25 pm
Picked this up at a flea market only because I thought it was unusual. Diameter is about 8 inches. It’s pretty thin aluminum and it seems to be from a small old motor. I don’t know what small motors used a three blade prop.
XR55
Re: Old prop ID
Postby XR55 » Mon Sep 24, 2018 9:57 am
Look very closely at the inside of the hub on the circular flat area separated by the shear pin slot for the letters and numbers code. Find the code and I will look up the application .
Re: Old prop ID
Postby outbdnut2 » Mon Sep 24, 2018 10:12 am
Champion 4LHD models (7.9 or 8.5 HP depending on year) came with a small diameter 3 blade prop that looks a lot like that. Hard to tell for sure from the photos. I have a couple and I can take a couple pics for comparison if I can find where I put them.
XR55
Re: Old prop ID
Postby XR55 » Mon Sep 24, 2018 11:02 am
This is a Johnson Motors prop.
Count
Re: Old prop ID
Postby Count » Mon Sep 24, 2018 9:51 pm
I don’t think there are any numbers on it but I’ll take another look tomorrow.
XR55
Re: Old prop ID
Postby XR55 » Mon Sep 24, 2018 11:20 pm
I can make out the letter A.
Lyks2Tinkr
Re: Old prop ID
Postby Lyks2Tinkr » Tue Sep 25, 2018 4:56 am
Looks like a prop on 2 of my motors. 1 is a 37 Johnson 110 and the other is a 1940 Champion D2D Playboy.
kees
Re: Old prop ID
Postby kees » Tue Sep 25, 2018 6:37 am
XR55 wrote:This is a Johnson Motors prop.
FWIW
no Johnson prop
checked my models and the 3-blads props on my Johnsons
are not even close with this one.
Re: Old prop ID
Postby outbdnut2 » Thu Sep 27, 2018 5:09 pm
Below are photos of a Champion prop from a model 4LHD that I mentioned earlier. Comparing, it is a bit different than yours, the main thing being that the slot for the shear pin is recessed on yours.
kees
Re: Old prop ID
Postby kees » Thu Sep 27, 2018 6:00 pm
outbdnut2 wrote:Below are photos of a Champion prop from a model 4LHD that I mentioned earlier. Comparing, it is a bit different than yours, the main thing being that the slot for the shear pin is recessed on yours.
this one is " ANTI clockwise " or a left rotating prop.
so this is a NO, I guess
I have a Champion with a "clockwise " prop, will check tomorrow
Users browsing this forum: No registered users and 7 guests
