Single hose fuel connector for OMC - oring replace?
Re: Single hose fuel connector for OMC - oring replace?
Postby FrankR » Mon Oct 01, 2018 9:25 am
Note that the NAPA (Sierra) 18-7111 for 301824 is wrong. It is too fat
Postby amuller » Mon Oct 01, 2018 10:51 am
Well, thanks. Looks like there are three numbers: 334913, 303598, and 331380. Dimensionally they are given as the same, so maybe a material or hardness (durometer) difference? Plus there is the Sierra number 18-7150. These don't seem to correspond to any standard industrial size, which must be the reason they are expensive, like $2 + /per each?
Postby amuller » Wed Oct 03, 2018 5:25 pm
I think there is confusion here between the tank valve parts and the connector parts, even though the heading clearly says "Single hose fuel connector...."
In any case, the fuel connector O ring is called a quad ring, which is something with a square section, on Marineengine.
They list two: 307858 for $1, and 322488 for $4. Both are OMC numbers, of course. Anybody know the difference?
Postby FrankR » Wed Oct 03, 2018 8:39 pm
amuller wrote:I think there is confusion here between the tank valve parts and the connector parts, even though the heading clearly says "Single hose fuel connector...."
What parts list shows quad rings? I guess I'm too old and haven't seen them in fuel connectors. Not a bad idea though.
Postby amuller » Thu Oct 04, 2018 10:42 am
http://www.marineengine.com/parts/johns ... =Fuel+Tank
Items #20. I'm going to pull out some rings from old connectors today and take a look.
Dougs Outboards
Postby Dougs Outboards » Sat Oct 06, 2018 1:49 pm
Amuller,
Just throwing this in for info, as I just found out about it a couple of weeks ago. Had a customers 9.5 Ev in as it would not stay running. Did my usual look over, and found an old single ine fuel connector o ring, motor side. He had the old dreaded grey Sierra hose. A nice member and friend sent me a few OMC "O" rings, but were too big, mighta been Sierra, dunno, but he got them from an OMC dealer. Out of desperation I tried a McMaster Carr double line o ring and it worked perfectly. Installed easily, sealed on the motor and off the motor (no leaks), tried the hose on and off several times and he reports success.
Dunno if these type of double line o rings will work with an OMC single line connector, but sure did with the Sierra type. You might try one if you have one.
If you need a few, let me know, we'll set ya up.
Doug
outboardrepair1 @ gmail .com
Postby amuller » Sun Oct 07, 2018 12:53 pm
Thanks for the info. I would like some to try. Do you have the McMaster catalog info?
These OMC tanks/lines have a lot of little bits that can act up.
I'm thinking it might make sense to use a translucent vinyl line between the motor connector and the pump so as to be able to see bubbles from leaks on the suction side. What do you think?
Alan
Dougs Outboards
Postby Dougs Outboards » Sun Oct 07, 2018 2:05 pm
Alan,
Ok simply email me and I will send you some. I do not have the MC info. I ran across a post from Frank a couple of years ago, and he had the info posted, so I bit, glad I did too.
outboardrepair1 @ gmail .com (scoot together).
I would have PM'd you, but alas, since I am not an actual member I cannot PM Yous guys. They changed that about a year ago.
The vinyl hose thing? Might be helpful to see what's going on. A lot of times you can listen, or see leaks around the o ring area. Let us know how it goes if you try it ok?
These o rings worked in the Sierra connector, didn't try in the OMC connectors yet, so you can be the guinna pig for us and let us know if you would be so kind.
Doug
Postby amuller » Mon Oct 08, 2018 9:38 pm
I have a few connectors around, but it's not obvious who made them. I'll look more closely.
Alan
Users browsing this forum: Buccaneer, destroyer85golf and 12 guests
