OMC Gear Case
labrador guy
Re: OMC Gear Case "update"
Postby labrador guy » Wed Oct 10, 2018 3:07 pm
Last night in the shower I got an idea of how to pull up that alignment pin. (I do my best thinking in the shower) I decided to drill the side of the alignment pin in the aluminum enough to make a divot so I could pry the pin up a little, with a stout ice pick. Well it worked like a charm! I will put some JB weld or epoxy in the hole when I assemble. Drill spot is under the bushing so it should not hurt a thing.
love it when a plan comes through!
dale
reivertom
Re: OMC Gear Case
Postby reivertom » Wed Oct 10, 2018 6:30 pm
That's what I like about this forum. You get 4 or 5 ways to do the same fix....and all you have to do is choose one.
elgin2
Re: OMC Gear Case
Postby elgin2 » Wed Oct 10, 2018 8:17 pm
Great idea.
bobw
Re: OMC Gear Case
Postby bobw » Wed Oct 10, 2018 8:38 pm
Outstanding, thanks for sharing! A lot easier than the process I went through.
1972 Evinrude 25202
Re: OMC Gear Case
Postby Chris_P » Wed Oct 10, 2018 8:44 pm
I wonder why the Engineers even made it like that in the first place! Very annoying.
Re: OMC Gear Case
Postby outbdnut2 » Thu Oct 11, 2018 1:18 pm
I'd look into replacing with a longer pin that can't be pushed in.
Users browsing this forum: Buccaneer, destroyer85golf and 11 guests
