Gearcase pressure tester
Postby outbdnut2 » Mon Oct 08, 2018 11:06 am
Looking at a nice homemade pressure tester in another recent post got me to thinking. I've been going to make a tester for a long time. I have an automotive radiator/coolant system pressure tester I bought 30 years ago and haven't used for many years, and I'm thinking of adapting that for gearcase pressure. It has a hand pump, checkvalve, and a gauge and is made to go from 0 to 30 pounds.
It looks nearly identical to the photo below (from O'Reilly auto's website) - I'm thinking all I have to do is replace the radiator cap on the end of the hose with a fitting to thread into the lower gearcase drain hole. Maybe use compressed air quick-connect fittings to switch back to the radiator cap. Has anyone done that? Your thoughts?
NJ-boatbuilder57
Re: Gearcase pressure tester
Postby NJ-boatbuilder57 » Mon Oct 08, 2018 11:19 am
Sure seems like it would work.
Postby Chris_P » Mon Oct 08, 2018 11:22 am
Yes would work fine.
I made mine from a tire inflator/gauge as in the picture below. I simply cut off the end that attaches to the tire and installed one from the link below it that fits into a gearcase.
https://www.ebay.com/itm/CDI-551-34TN-T ... 1438.l2649
tire inflator.JPG (25.66 KiB) Viewed 243 times
RCO
Postby RCO » Mon Oct 08, 2018 12:54 pm
That's what I did to make mine. I added quick connects so I could go back and forth from auto to outboard testing. I drilled a 3/8" NC stud to let the air through and threaded that into a male quick connector with a thick rubber washer to seal it to the gear case. Works great, and the 3/8 thread fits OMC, Merc, and Chrysler at least.
Steve D
Postby Steve D » Mon Oct 08, 2018 1:22 pm
outbdnut2 wrote:I have an automotive radiator/coolant system pressure tester I bought 30 years ago and haven't used for many years, and I'm thinking of adapting that for gearcase pressure.
I also converted something similar to use for gear case testing and dual hose tank pressure testing.
pressure tester.jpg (868.91 KiB) Viewed 222 times
pressure tank tester.jpg (127.86 KiB) Viewed 222 times
"He said we wouldn't get the treasure we seek on account of our obstackles."
rjoynt
Postby rjoynt » Mon Oct 08, 2018 4:21 pm
I called Stevens a few years ago and bought a rebuilt tester for half price. Great folks to work with. Then recently bought the vacuum version on eBay at a great price.
Bob Joynt
Secretary/Treasurer
Western Reserve Chapter - Ohio
https://wrcoutboards.org/
Postby outbdnut2 » Mon Oct 08, 2018 4:35 pm
Thanks guys, I think I'll convert my radiator tester and it never occurred to me to use it to test pressure tanks.
Bob D
Postby Bob D » Mon Oct 08, 2018 10:31 pm
Steve D, what pressure do you use to check the two line tanks?
Bob D
Steve D
Postby Steve D » Mon Oct 08, 2018 10:55 pm
Bob, I think I remember someone on here saying that these tanks run on only 3-4 lbs. but I usually test at around 5-6. That's enough to detect a leak and then spray soapy water to isolate it.
Postby fleetwin » Tue Oct 09, 2018 6:50 am
rjoynt wrote:I called Stevens a few years ago and bought a rebuilt tester for half price. Great folks to work with. Then recently bought the vacuum version on eBay at a great price.
The folks at Stevens are very nice, they answer the phone, and return calls. A rarity these days. Stevens also sells the fittings that screw into the gearcase separately at a very reasonable price. The key to any pressure vacuum gage is a good gage that reads low enough for this work, and that doesn't have its own internal leaks....Nothing more frustrating then trying to find a gearcase leak only to discover that the leak is actually in your pressure tester rig....
