Gearcase pressure tester
BillW
Re: Gearcase pressure tester
Postby BillW » Tue Oct 09, 2018 5:15 pm
I made my radiator tester work for a gear case tester. The pressure part works fine. The down fall compared to the Stevens is that they give you a bleed off valve; whereas with the radiator tester, it just bleeds off as you unscrew the fitting from the gear case. No biggie, just a little crude.
Users browsing this forum: No registered users and 6 guests
