Row Boat Motor Tank Repair
Re: Row Boat Motor Tank Repair
Postby Buccaneer » Wed Oct 10, 2018 7:49 pm
No soda blaster, but I can definitely reduce pressure and hold
the gun further away from the work. I think my supply air
to the gun is set at about 90 psi now, any higher the compressor
lags behind, but it will blow sand at a lot less pressure.
Postby Richard A. White » Wed Oct 10, 2018 7:50 pm
The lower the pressure the less chance of warping the base metal..
bill_loveland
Postby bill_loveland » Wed Oct 10, 2018 8:20 pm
Looks like you got it apart without distorting anything - good job!
bobw
Postby bobw » Wed Oct 10, 2018 8:36 pm
Yes, good job getting it apart with no apparent warpage of the metal. Hopefully, you can get the rust cleaned up and salvage the thing. Like Chris suggested, would be good if you had access to a soda blaster or some fine glass bead.
1972 Evinrude 25202
Postby outbdnut2 » Thu Oct 11, 2018 1:16 pm
Nice job of taking it apart!
I was just wondering, since the problem is mainly rust, would this be a good candidate for the electrolysis rust removal?
Postby Buccaneer » Thu Oct 11, 2018 9:24 pm
outbdnut2 wrote:Nice job of taking it apart!
Not sure if a person would end up with a worse case of "Swiss cheese" using electrolysis
vs. sandblasting or not. I sandblasted the inside of the tank today then scrubbed
it the best I could with little wire brushes and more phosphoric acid.
The inside of the cover I didn't sandblast, as I thought that would be the most
likely to "warp", but rather used a drill with wire wheel and
acid. Hopefully tomorrow I'll finish up any body work on it, then solder the lid
back on the tank. Guess I'll just tape all the pin holes and seal it with Red Coat
when it arrives. Hopefully the Red Coat doesn't cause problems with the paint lifting
off the pin holes.
Postby Dave Bernard » Thu Oct 11, 2018 11:01 pm
can you coat it before you put the top on ?????
bobw
Postby bobw » Thu Oct 11, 2018 11:22 pm
Sure looks a lot better than when you started! With the Redkote sealer, I think you'll have a good tank.
1972 Evinrude 25202
bill_loveland
Postby bill_loveland » Thu Oct 11, 2018 11:26 pm
off the pin holes.
tape the inside
couple coats of primer on the outside
then seal inside
Lyks2Tinkr
Postby Lyks2Tinkr » Fri Oct 12, 2018 1:52 am
Solder the tank together. Slosh with MEK or Acetone to make sure it's clean and then line the tank.
If you prime 1st then clean you stand a good chance of acetone getting on the primer and messing it up. I have experience in the above :-)
Users browsing this forum: Google [Bot] and 7 guests
