Home Forum Ask A Member OMC pressure tank rebuild
  • #10106
    mike-stroz
      Just picked up a Fleetwin in good running condition, new water pump, coils, etc but I hear air leaking out of the fuel fitting and a few bubbles from the gasket around the top of the pressure tank. Are there any how to guides on how to rebuild these things? I want to rebuild the fitting and put new gaskets and seals in the tank. Just never done one before so I don’t know where to start
      #77138
      david-bartlett
        This is a pretty straight forward process. I would take it apart first to see what you need. Sometimes they are just dirty.
        Take some pics of the check valve placement and have at it.
        #77153
        mike-stroz
          I think I’m more worried about breaking the fuel fitting than anything. It looks like the tank itself just has a bunch of screws. I didn’t notice before but the primer button is broken off, does anyone sell replacements?
          #77200
          Steve D
            You could place a Wanted to Buy ad for the push button parts and there are a few guys have rebuild kits:
            http://www.marineengine.com/newparts/pa … num=301815
            http://www.marineengine.com/newparts/pa … num=302561
            http://www.marineengine.com/newparts/pa … num=305713
            http://www.laingsoutboards.com/johnsone … parts.html
            https://richardsoutboardtools.com/
            http://www.franksoutboardtools.com/fuel … xture.html
            elgin2
              That fuel connecter fixture is worth it`s weight in gold.
