Home Forum Ask A Member Johnson 70EL79R
  • #11411
    bill-loveland
      If I’m reading the numbers right, it’s a 1979 70 hp, 20 inch shaft
      What do the E and R designate?
      #83817
      outbdnut2
        The E is Electric start. There is no T in the number so it’s a remote control motor – no tiller. Not sure what the R at the end stands for – maybe a revision mid year?? Somebody here should know.
          quote outbdnut2:
          Dave is right
          1979 70hp (20"/long transom no power trim and tilt) The "R" at the end of the model number indicates some sort of mid model year change, probably something very minor….
          Great engines for sure…
          bill-loveland
            Thanks guys. The pics of this one show a cylinder in the center of the clamp bracket – doesn’t seem to be powered – was that a damper for kickup?
            #83828
            bill-loveland
              Never mind – I’m mixing up two different motors
              #83829
              bill-loveland
                Evinrude E70EL CNB
                1982 70 hp long shaft electric start, no trim and tilt, right?
                This is the one that has what looks like a hydraulic ram between the clamp brackets – is that a damper for kickup?
                #83832
                  quote bill_loveland:
                  Evinrude E70EL CNB
                  Yes, and yes. Actually, it might also be a gas charged shock to aid in manual tilting.
                  #83833
                  bill-loveland
                    Thanks – now back to the Johnson – the seller says it has working trim and tilt – could that have been added later?
                    #83835
                    chinewalker
                      You ended up with two triples? Thought you were headed down there to get one!
                      #83836
                      bill-loveland
                        Long story – these are two others
