Home › Forum › Ask A Member › Shift Lever › Re: Shift Lever
April 22, 2015 at 8:44 am
#14484
That is what I would think as well next. I just had one. Changed from a long shaft, to short shaft, and the guy used the wrong shift rod in the gearcase. There are a few, some that are very close, but will not work. Less likely but happens, especially If you know it used to be a long shaft motor.
