Home › Forum › Ask A Member › Scott Atwater, 1958 10 hp, drive shaft pin? › Re: Scott Atwater, 1958 10 hp, drive shaft pin?
April 25, 2015 at 4:26 am
#14701
Hey Dave, I’m pretty sure the pin locates the forward gear on the shaft by going thru the shaft and the inner retainer at the same time. Without it, the gear may climb the shaft or the shaft may spin inside the retainer? I know my ’56 has one in it and you can probably make one easy enough.
