Home Forum Ask A Member How Important is OMC Ignition Timing? Re: How Important is OMC Ignition Timing?
#15490
RICHARD A. WHITE
    So, I made me a tool today, Used ohm meter set to audible to stop make the effing racket just as points break.
    Reading the manual. it states that you set the gap approximately 1/4 inch past the initial opening. This is for the Phelon ignition. Does that sound right?
    Thanks
    classicomctools@gmail.com
