Home › Forum › Ask A Member › Tight rings › Re: Tight rings
May 9, 2015 at 3:58 pm
#15583
If the rings are too thick they will indeed be too tight or not springy enough. If you have a lathe available you can make a fixture to hold the ring in its compressed state and cut the ID as desired. I have just used a pipe with a step cut in the end of it and superglued the ring in place to turn it making light cuts. The superglue holds great and is easily released with a light tap. Hope this helps.
Jim
