Re: JW 12 R
Home › Forum › Ask A Member › JW 12 R › Re: JW 12 R
May 31, 2015 at 4:05 am
#17265
did a quick check. 80lbs compression spark on top cyl only. looking in the inspection plat on the flywheel the coils points and condensers look pretty new will have to pull the flywheel and clean the points and check the rest. just for kicks I pulled the choke and on the 2nd pull it fired for a few seconds looking good. now I will set it aside till I get time for it.
