Re: Two stuck flywheels
Home › Forum › Ask A Member › Two stuck flywheels › Re: Two stuck flywheels
May 30, 2015 at 12:06 pm
#17188
I think if you have cracked or blew out the crank shaft , your method may be in error. I have never seen a crankshaft fail with the nut left on the crank even with the top after it has been loosened. As mentioned earlier place the nut back on crank, even with top of crankshaft. Then place the puller.
