Home › Forum › Ask A Member › Lower unit pressure/vacuum Test › Re: Lower unit pressure/vacuum Test
June 4, 2015 at 3:03 am
#17562
Thanks, yes I have been turning shafts and shifting under pressure in the bucket, but it has to be there, the leak that is
Fleetwin, when you ,emotion going to 16 psi for the spaghetti and o ring I assume the seals should hold that too? They will just seal tighter?
I have seen those fail at the 7 psi point too but have never gone higher. At this point I guess
Since I know there is a leak I need to test until failure……systematically of course
