Home › Forum › Ask A Member › QD19 Overheat Question – Update › Re: Question For The OMC Experts
June 25, 2015 at 1:37 pm
#18901
Yes, at this point, I would go with mumble’s drilling advice. It will be easy enough to plug this hole if the fix does not work out. The only other idea would be to find a different mid section with the longer divider wall between the shift linkage and exhaust cavity, but it would have to be from another 58 model.
