Elto Ace coil
Elto Ace coil
Postby outbdnut2 » Wed Apr 27, 2016 4:24 pm
Anyone know of an available magneto coil I can modify to fit a 1.8 HP, 1940 Elto Ace?
Tom C
Re: Elto Ace coil
Postby Tom C » Wed Apr 27, 2016 6:20 pm
I put a modern OMC coil in mine. Had to modify the laminates but I got it to fit and works great.
Re: Elto Ace coil
Postby Garry in Tampa » Wed Apr 27, 2016 11:31 pm
I hope this helps . . . :D
1939 Ace - '40 Ace had a rubber clutch in the propeller hub ...
Dwood148
Re: Elto Ace coil
Postby Dwood148 » Mon Sep 11, 2017 4:58 pm
Tom,
I too need a coil for my 1940/1941 Elto ACE 4351.
Can you let me know what OMC coil it was that you have used?
Re: Elto Ace coil
Postby Tubs » Tue Sep 12, 2017 10:10 am
Its pretty common for this magneto
to loose spark because of corrosion
in the point assembly. Disassemble
the points and clean everything and
recheck for spark. These coils are
rarely bad. I bet I have had 20 or
more motors with this magneto
that wouldn't spark when I got them
but it was never the coil. Its always
good to know if there is an option if
you do find a bad coil so how about
a picture Tom?
Pal Points - 2.jpg (69.2 KiB) Viewed 447 times
Users browsing this forum: Brook N., Google [Bot], RPSIII and 12 guests
