1958 Sportwin 10 flywheel fit 1955?
ShoestringMariner
Postby ShoestringMariner » Tue May 17, 2016 8:22 pm
I have a 1958 Sportwin 10 that I scrapped (seized)
I've had a guy contact me that needs one for a 1955...will they interchange?
thanks in advance
beerman57
Re: 1958 Sportwin 10 flywheel fit 1955?
Postby beerman57 » Tue May 17, 2016 8:44 pm
compare part numbers, or size and location of the magnets to the flywheel key.
Postby FrankR » Tue May 17, 2016 9:12 pm
I'm thinking it won't work. Doesn't 1955 have the old style recoil starter with 3 pawls, and 1958 has the one with a single plastic pawl?
retiredoz
Postby retiredoz » Wed May 18, 2016 12:03 am
It should be a '56. Looks to me like that's the first year for the Sportwin, and it uses the later-style (single-pawl) starter. So I'm thinking the '58 will drop right on there.
Postby Garry in Tampa » Wed May 18, 2016 12:41 am
1955 ten would be a QD Johnson - First year of 10 horse Evinrude Sportwin was 1956 and it DID have the single pawl starter. . . . . . :D
Postby fleetwin » Wed May 18, 2016 11:07 am
Isn't there something about the 1958 flywheel that is different that the 56-57s also...Something about the flywheel diameter being slightly smaller? The rewind pulley might be unique as well. I can't confirm this, but remember this past discussion....
Chinewalker
Postby Chinewalker » Wed May 18, 2016 12:29 pm
I believe you're right. The small flywheel, I think, came about when they went to the smaller gear case. Trying to put the 10 on a diet, so to speak. The recoil housings were the same, but the rope plate was different. The nylon starter pawl pivot was closer to the center on the 1958 & up versions.
Steve D
Postby Steve D » Wed May 18, 2016 2:09 pm
Differences between the '56-'57 and '58 and up 10 HP.
For the recoils the connecting links and posts were moved in for '58 and up 10 HP. On the flywheels there is a different dia. up top for the pawl engagement. Under the flywheels the same diameter for coil heels.
ShoestringMariner wrote:I have a 1958 Sportwin 10 that I scrapped (seized)
thanks in advance
'55 was a different pawl setup so they won't interchange.
Can't you see it, Everett? Them sirens did this to Pete. They loved him up and turned him into a...horny toad!
Postby fleetwin » Wed May 18, 2016 2:41 pm
Good info Steve, thanks!
ShoestringMariner
Postby ShoestringMariner » Wed May 18, 2016 9:02 pm
Wonderful, thanks everyone
Users browsing this forum: h20lew and 11 guests
