Home › Forum › Ask A Member › Cub/mate and pal condensers
- This topic has 6 replies, 4 voices, and was last updated 9 years, 1 month ago by Mumbles.
March 26, 2015 at 12:59 am #1028
what condensers are people using for the Cubs/mates and pals and where can I buy them? 🙄
March 26, 2015 at 5:49 am #12796Hey Randy, those motors originally came with condensers rated at 0.1 uF with part numbers 171448 and 171449. Good luck on finding those at your dealers so the way to go now is to use modern capacitors with the same rating. Excellent replacements are the Sprague Orange Drops or Vishay brand caps with the same uF rating. There’s lots of room under the flywheel for the OD’s while the smaller axial Vishays will fit most mags. I’ll try and find the PN’s for both of them but meanwhile check on eBay to see what’s out there.
OK, I found a link for the Vishay caps.
http://www.digikey.ca/product-search/en … =bc2607-nd
And the Orange Drops.
http://www.ebay.com/itm/Sprague-Orange- … 2308ca550d
March 26, 2015 at 10:42 am #12799Thanks mumbles I’ll give it a shot! 😎
March 26, 2015 at 2:28 pm #12809OK Mumbles , please give us a electronics refresher on parallel vs series connection of capacitors. I’m looking at the two in parallel 0.15 uf and thinking that that results in 0.075 uf … correct ?
Joe B
March 26, 2015 at 2:35 pm #12811Oh’ and by the way… the Vishay caps are especially useful because of their small physical size. They can be retro fit into many of the old metal capacitor cans… like on the old RBM’s . There was a lot of research done by member Jeff R from Arizona in identifying these caps as about the best available for magneto use., both from an electronic and physical size perspective. Thanks Jeff.
Joe B
March 26, 2015 at 2:59 pm #12812quote JoeCB:OK Mumbles , please give us a electronics refresher on parallel vs series connection of capacitors. I’m looking at the two in parallel 0.15 uf and thinking that that results in 0.075 uf … correct ?Joe B
For capacitors in parallel (tied together at both ends) and resistors in serial (in a row) simply add the values.
Capacitors in serial (and resistors in parallel) are calculated using the "harmonic mean":
the reciprocal of the sum of the reciprocals or 1 / (1/a + 1/b ……)March 26, 2015 at 5:09 pm #12816quote JoeCB:OK Mumbles , please give us a electronics refresher on parallel vs series connection of capacitors. I’m looking at the two in parallel 0.15 uf and thinking that that results in 0.075 uf … correct ?Joe B
No, wrong. 0.15 + 0.15 = 0.30
If they were wired in series I’d still have a rating of 0.15 uF but by juggling them around in parallel I can come up with what I want.
