1936/37 Evinrude Sportsman 2.5hp
gjonz
Postby gjonz » Sun May 03, 2015 9:21 pm
What kind of modern spark plugs should I use?
Thx!
Greg
legendre
Re: 1936/37 Evinrude Sportsman 2.5hp
Postby legendre » Sun May 03, 2015 10:00 pm
NGK! =P
While totally unintentional, I can be somewhat condescending. (That means I talk down to people.)
gjonz
Postby gjonz » Sun May 03, 2015 10:24 pm
Since it is a nice fresh restoration...and I'm trying to stay original...how about Champions...like I always use.
Anyone know what a good modern Champion plug would be that works in this.
Thanks!
Postby Mumbles » Sun May 03, 2015 10:43 pm
The original plug was a J1-15 so you may have to do a Google search to find a modern equivalent.
legendre
Postby legendre » Sun May 03, 2015 11:04 pm
Hey Greg,
gjonz wrote:What kind of modern spark plugs should I use?
Thx!
Greg
What, if anything, was in the hole when you got the motor?
I'm sure someone who knows will eventually show-up with data, but if not, you'll just have to pin down the basics (thread size / pitch / reach) and pick a plug in a middling heat range - like an NGK 6 or 7 or a Champion 6 and try it.
On these old motors, just about anything (heat range-wise) should be OK for initial shake-down runs in a tank, etc.
Garry in Tampa
Postby Garry in Tampa » Wed May 06, 2015 10:07 pm
The more modern short Champion spark plugs begin there part number with "C". A following "C" indicates a copper core. which is advertised as having better heat tolerance and an extended heat range.
Users browsing this forum: Google [Bot], jasper60103 and 6 guests
