Can anybody tell me what year this is the only numbers i can find are ACN097370100? Also if you could post a parts list i could sure use it thanks steve
That is not a number we can do anything with. Can you give us an idea of the era we are dealing with? Two piece aluminum cowling = 50s, fiberglass cowling gets us into the 60s & 70s. If you have the ability to post a picture then we may be able to start to help. Up until 1979 Johnson had the year in the model number most of the time after the 60s. Hope that helps some.
25 horse Johnson’s built from 1980 to 1999 would have there model number start with 25. 2000 to 2005 would start with J. I am familier with the RD-10 through RD-17 25 horse model Which leaves the late ’60s and 1970s as likely years of manufacture. UNLESS it is a fuel injected model built by BRP. . . . 🙂
