Home Forum Ask A Member 1970 85 hp V4 Re: 1970 85 hp V4
#59632
    quote amuller:
    It will be a few days before I get it out on the water to see if it really performs…..
    Any advice on tilting these things? I haven’t tried it, but seems like a bear to do from inside the boat. If I’m reading the catalogs correctly, they didn’t have power tilt/trim until around 1976.
    Yes, an absolute bear to tilt for sure. You must overcome the resistance of the shock absorbers as well. OMC did make an electric tilt (no trim) for these engines, but don’t think you will find one that is still in decent condition. The transom bracket must be disassembled to install the hydraulic tilt cylinder as well…
    I think tempo or some other aftermarket makes a pretty nice tilt lever arm that locks into the shroud’s tilt handle, affordable and effective.
    Hope it runs OK. Be sure to drain and refill the gearcase after you water test, just to ensure no more water is getting into the gearcase…Might be a little milky because the new oil has mixed with any residual water/moisture that didn’t drain out…
