Re: Evinrude 3 hp Lightwin 3012 diagnosis
Home Forum Ask A Member Evinrude 3 hp Lightwin 3012 diagnosis Re: Evinrude 3 hp Lightwin 3012 diagnosis
Topics: 1074
#60021
Finally got the Lightwin carb working correctly.
Ended up drilling out two of the little brass plugs
in the fuel passages, and rodding them out
with a wire, and got the low speed circuit
working again! I cut up a little lead sinker
and tapped it in the holes to seal it up,
then put a dab of loctite on each one for good luck.
So far, so good!
