Home Forum Ask A Member Eisemann 71L magneto Re: Eisemann 71L magneto
#65973
sbrown21
    Richard, I moved the coil to the other end of the coil heel over the cuts. I put the flywheel back on and tested coil showed good. Turned the flywheel no spark . Took the flywheel off and found that the screw coming out of the coil was touching the bottom of the flywheel. Cut the screw down to half it’s length checked the coil ( bad ) did I ruin the coil by the plug wire screw touching the bottom of the flywheel or something else ?
