Re: 1937 Sea King / Thor 2.4 hp Water Pump
Home Forum Ask A Member 1937 Sea King / Thor 2.4 hp Water Pump Re: 1937 Sea King / Thor 2.4 hp Water Pump
Topics: 1072
#73549
I made an inlet check valve today with a brass fitting,
steel ball. Used a couple of drill bits to make the
seat area, then lightly peened the ball into the seat
to help make a better seat. I then pinned the ball
inside the fitting with thin brass rod.
I only had one size / weight ball to work with,
so not sure if it’s sized right for the discharge check.
I "hope" it will work!
