Home › Forum › Ask A Member › T2Stroke › Re: T2Stroke
Don, I took pictures of the flywheel nut and the roll pins with the throttle level at wot. It does not appear as if the flywheel nut has been tampered with. It also does not appear as if the roll pins are fully vertical, likely this is a side effect of me adjusting the arm so that the plates fully close at idle. I would trade off the higher top end speed for a more preferable smooth idle. In regards to the idle/rpm/tach ; WHEN it is actually idling, it seems like a very appropriate rpm. I do believe the tach is omc, I will check out the back this afternoon. I will let you know what I come up with in regards to the TDC tool. It looks like next weekend will bring some decent weather, if so I will take her out and attempt to get some video footage. Heres the pics I took.
